  #1
Old December 23rd, 2007, 12:27 PM
kovacs307 kovacs307 is offline
Default mariner 90hp no compression
hi. this is my first posting..i have a 1995 90 hp 3cyl. mariner.the boat sat for a few years ,not sure how many. at first i didnt have any spark. i changed the power pack and got spark. i hooked up the water to it , had to spray a little eather in it to get it satrted. water come out the pee hole ok. after about 60sec. the motor made a not good sound ,apuff of white smoke blew out the exhaust and it died ...i checked the compression and got 30lb on #1...10 on 2.....30 0n 3..........could any one give me a clue as to what happened and what me next step should be to fix this thing.......
thanks,,,,,Al
  #2
Old December 23rd, 2007, 01:17 PM
Laddies Laddies is offline
Default Re: mariner 90hp no compression
That sounds like someone sprayed to much starting fluid in the engine, any is to much.
  #3
Old December 23rd, 2007, 01:43 PM
JB's Avatar
JB JB is offline
Howdy, Kovacs.
Welcome to iboats.
I suspect that the ether took out the head gasket at least, and maybe holed a piston or two.
First, remove the head. Tell us what you see.
__________________
RED SKY at night. . .
JB
  #4
Old December 23rd, 2007, 01:51 PM
thanks for the replys..i didnt think a little i meam litte squart could cause such a big problem....ill pull the top of the cylinders and let you know what i see.............thanks,,,,Al
  #5
Old December 23rd, 2007, 06:27 PM
ddennis's Avatar
ddennis ddennis is offline
ANY starting fluid is TOO much! If you have to use a starting aid, use some premix in a spray or squirt bottle... No lubrication in starting fluid...sure way to damage an engine. Good luck and welcome to Iboats!
  #6
Old December 23rd, 2007, 06:55 PM
Thurst Quick Starting Fluid made by Gunk says right on the can in big red letters ,, FOR AUTOS, TRUCKS , OUTBOARD MOTORS, ECT...the directions say to spray in each carb. for 2 to 3 sec. then start..I wonder why they would say this if just a fraction of a sec. squart which i applied to each carb. would ruin a motor....I've used it on lawnmowers , chain saws, cars and never hurt any of them...and it also says on the can that it contains a lubricant and a corrosion inhibitor.. ill contact them and explain what happened. maby they will buy me a new motor.......I just assumed it was ment for what it is advertised for............
what do ya think?????????
  #7
Old December 23rd, 2007, 07:24 PM
Don S's Avatar
Don S Don S is offline
The only reason starting fluid is necessary to begin with, is because there is a problem with the engine, ignition, or the fuel system.
Starting fluid does nothing but make it possible for the owner to start the engine without having to fix it first. Think about it.
__________________
Don S.
Why is there never enough time to do it right the first time,
But always enough time to do it again?
Please, NO PM's (Private Messages) regarding boat/engine problems.
That is what these forums are for.
Only forum/moderator issues will be answered in PM's.
  #8
Old December 23rd, 2007, 08:24 PM
Just because a company advertises something don,t make it the truth. That aside your engine does not have a cyl. head to remove that is only a water jacket cover not a head. You may have damaged the rings or caused the lands to collapse so first try to use some oil in the cyls to see if it will lossen the rings if you compression does return you may take a squirt can and some fuel and oil mix and prime the engine with that to see if it will start and if it does you will need to clean the fuel system as the carbs are dirty or the inlets are stuck
  #9
Old December 24th, 2007, 02:59 PM
thanks Laddies .......thats what i thought...ill try that after Christmas and let ya know what happened..........MERRY CHRISTMAS TO YOU AND YOURS
Al
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1976 90hp 6, low compression in one cyl. hilljack Mercury & Mariner Outboards 6 August 28th, 2005 08:46 AM
1991 90hp mariner and 1994 115hp mariner JC1933 Mercury & Mariner Outboards 4 January 12th, 2004 09:38 AM
1991 90hp mariner and 1994 115hp mariner JC1933 Force & Chrysler Outboards 1 January 11th, 2004 06:38 PM
compression on a 90hp johnny alanR1 Johnson & Evinrude Outboards 3 December 3rd, 2003 06:18 AM
1990 Mariner 3cylinder 90HP compression numbers? jmmm Mercury & Mariner Outboards 6 September 3rd, 2003 01:09 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
