Re: MARINER 45 -spinning my wheels
Hi Artee,
The prop hub is actually a rubber bushing that sits between the prop and the splined shaft. Or let me add more detail.
If I were to install my prop from scratch:
1) Slide big copper washer with tapered hole onto the splined prop shaft.
2) Fit rubber prop hub into aluminium prop
3) Slide prop (complete with rubber hub) onto prop shaft
4) Fit brass interface bushing onto splined propshaft and engage with rubber prop hub.
5) Fit tongued washer
6) Fit Nyloc prop nut and tighten
7) Bend 3 tongues to engage with brass interface bushing.
It's that rubber hub that we're refering to. I hope you have this setup.
here's a nice pic of the lot. The biggest component (rear of pic) is the rubber prop hub
