Oohh, that title doesn't sound good.......
This is for a 91 V4. After the last trip, parked the boat with the leg down to the vertical position. The next day I notice a gunky (oil/gas) mixture running down the leg. The same thing happened after I had the motor running and fogged it for winter storage.
It was coming from under the main engine cowling, where it bolts onto the leg. Under the hood, it is quite clean, even with minimal residue from a typical 2-stroke. There are no apparent leaks.
It's not straight oil/fuel since it slowly seeps down. Looks like unburned exhaust.
Any idea where or what would cause this?
