1986 Yamaha 90hp. the ground is ground to the block, but the positive wire gets buried behind the coils and all the other wires in the area.
so its not just closing based on engine temp NO? it only closes while you are starting NO. PUSHING IN ON THE IGNITION SWITCH WITH SWITCH ON. so to test do i pull the plug wires and crank the engine NO, and then test volts NO?
