I have had some problems with idle on a 1989 60HP, I have the max spark advance set no problem runs great off idle. Heres my problem setting my idle advance, I can set it on the hose (idles good) but when I get it in the water I have to turn the idle screw about 2 turns to get it to idle and hence the timing is off. when I set the line up on the roller for the throttle pick up and try to set the timing it wont idle. PS carbs are clean, comp is within 5psi in each cylinder. engine seems to only want to run at a very fast idle (ie more timing) a little faster than I like on the hose. no RPM gage.
