I took a 23ft 1992 Maxum 5.7 Mercruiser out for a test drive for considering buying. We were running @ around 3200 rpm when we lost all drive. I thought the prop fell off! Motor revs fine but no forward or reverse. (prop is there!) Had to be towed back (big bummer). Supposedly there is just over 200 hours on this boat.
The problem is that we really like the boat and know that we will run into things like this, but I'm trying to figure out just how bad this could get.
What do you think it could be? Internal outdrive parts? Shift cable?
To go along with this story. We had the owner start it for us with ear muffs, but when we backed it into the lake it wouldn't start. I thought I flooded it. After some time I tried again, nothing. Pulled it off the ramp, tried it, BOOM, started right up. When back to the water, same thing, wouldn't start. Pulled it out of the water, started it, rolled it into the water, everything went fine. We ran it awhile then tried to turn it off and start while in water, it started fine from then on, weird!
Then under way we noticed the bilge running non-stop. After inspection out of the water the rubber hose, bellow, whatever it's called, for the exhaust was cracked and had several holes that show when unit is trimmed all the way up. We figured this was allowing too much water in when we trimmed up the motor while submerged. And maybe the extra water in the exhaust is why it wouldn't start at first. I don't know. Any opinions? Hope I haven't rambled on too long. Thanks!
