Hi guys, on a Evinrude 35 hp Electric start, Motor was with steering system and remote control, I did convert to a tiller outboard but I’m trying to install a omc Push to choke key switch on lower pan, Do you guys know witch wire( color) on the harness( above picture) is to trigger the solenoid? Witch cable is to shut the motor off and electric choke? I will really appreciated any help that I can get
Thank you
Reason: resize
To trigger the solenoid or choke would be the violet with white stripe as FR said, maybe yours has been rewired?? Trace the purple wire back, does it go to engine primer solenoid coil? If so that is it. As far as the kill, it should be black yellow as stated. Trace both black wires back. 1 will go to the engine chassis or battery negative. The other should go to engine ignition kill circuit. That will be the one that you want.
