richpaladino
- Oct 14, 2007
- 1
Help. I am a new owner of an old pontoon boat and don't have any experience with motor maintenance. These are the symptoms I am dealing with.
The motor always starts and idles fine, the difficulty is in the ability to get the engine rpm up to high levels. When transitioning to higher rpm the motor always begins to bog down like it is getting no fuel. If I hit the choke during the transition it will immediately respond to higher rpm's, but never really seem to get to the max rpm, and then will begin to die out again. If I hit the choke again it begins to speed up and the cycle repeats.
Filling the tank completely full of gas seemed to make things better but still didn't get to the full rpm, or stay there.
At one time, getting the prop out of the water and reving it up to full rpm and then putting the prop back in the water would fix the problem for a while.
I changed the plugs but that didn't seem to make any difference.
It seems like it must be a fuel problem or something similar to a timing advance problem.
Any recommendations on what potential simple fixes to this problem may be that I could try. Or easy parts that I could exchange? One individual mentioned that it could be the "stator" which is under the flywheel so that would require hundreds of $$$$ to fix.
Any help would be appreciated.
