Mercruiser 4.3LXGENII Normal Engine Temp?
kram66
I have a "97" Mercruiser 4.3LXGENII that averages about 180-185 degrees when run hard......Ive never seen it above 190 degrees.
Is around 180 degrees typical for this engine?
Re: Mercruiser 4.3LXGENII Normal Engine Temp?
Ayuh,........
If it's Raw water cooled,.... It's running a tad Warm,+ I'd change the Impeller........
If it's Freshwater cooled,....... That sounds about Right.........
