I just acquired a 1976 Johnson that after not being run for 6 years started first pull.
The thing is it would die at idle and run fair with more throttle. When I pulled the choke out at idle, it would run for a minute or two more before dieing. I was 100% sure I had a gummed up carb and was about to call it quits for the night when I decided to dink around with it a minute more. It was hard to start so I pumped the bulb, which was still quite hard and fired it up again.
When it went to die, I pumped the bulb and it stayed running at idle very well. If I pump the bulb it stays running just fine. The thing is, I tried two different hoses and the issue remains the same, the bulb is not rock hard but is very full and pretty solid to begin with, however if I don't give it that little squeeze, the motor will die within 30 seconds at idle. Is this a fuel pump issue or what??????? Help!!! Thanks much in advance.
