Re: engine Mounts AQ125b Volvo270 I/O 19'Openbow
I have an AQ125A mounted on my Bayliner. ( I am not sure if there is much of a difference between an AQ125a or an AQ125b) There is no side supports on mine. I have not seen these Volvo engines with side supports installed with them. If the engine is sturdy, then I would not worry about it, but you can try looking at a parts diagram for your engine at the Volvo Penta website to see if there was side mounts. If you are looking for the dipstick location, then try looking on the top of the engine between the air cleaner (filter) and the expansion tank (if yours has one). If not, look behind the valve assembly cover. (The big metal thing that says "Volvo" on it) That is were my dipstick is located. It is a long tube that travels to the back of the engine. I hope this will help.
Thanks
__________________
'83 Bayliner Capri - 1950 BR
117 HP Volvo Penta Sterndrive
'87 Kawasaki JS 550cc Standup
