Re: Boat leaning to one side while throttling up?
You're doing the right thing. Well your prop turns one way. If it turns left, that would maybe explain why your boat lists to Starboard on acceleration . . . A piece of the puzzle. No, frankly, I have never seen trim tabs on a Tournament hull, I do not agree with Tashasdaddy about Smart Tabs in this case. Helm adjustable tabs would definitely fix the problem, but again I have never seen them on a Tournament boat. Your type of hull has a very flat bottom. There are a few boats out now (Tige comes to mind) that have one large trim tab for digging a big wake. It would not solve the listing. Sooooo, I think we need to spend a little more time fingering this out. One of the reasons that most boats have a right hand rotation prop is that the operators weight is usually on the Starboard side to counteract the prop torque. In the case of your boat, you are possibly getting a double whammy . . . your weight and the left hand rotating prop (if so). If it has a right hand rotation prop then this would be another discussion. My thoughts are that you have a left hand rotating drive and prop. Some props might be better (less tendency to cause the list) as Salty87 noted ^^^^^. Also, I'd look at other things on the boat too. Which side is your battery on? Tools? Stuff? I'd move heavy stuff to Port and light stuff to starboard. I am guessing that you have storage under the passenger (port side) rear facing seat back-rest forward . . . use it. Can you talk with the previous owner? Maybe something he learned to live with? Maybe he changed the trans and that's why it is left hand rotation (if in fact it is). Boats take some noodling. Many variables and lots of little things to know. Also, being a Tournament style boat you might check in on a good Waterski forum, they may be more familiar than this group although the general knowledge here is second to none. Good luck!! Be patient . . .
