The choke solenoid does not seem to be working when cranking the engine. You turn the key and the starter gear ingages but the butterfly arm attached to the choke solenoid rod does not move allowing the engine to get gas for firing. Is the key switch bad or do I need a new choke solenoid. Thanks for any suggestions and/or help.....
