  #1
Old April 9th, 2003, 09:40 AM
mjcombs mjcombs is offline
Default how can i paint my 14' aluminum boat
looking for anyone's answers on how to paint my 14' semi v hull aluminum boat
  #2
Old April 9th, 2003, 10:15 AM
NathanY NathanY is offline
Default Re: how can i paint my 14' aluminum boat
This is how I did mine: Used a wire brush and took it down to bare metal, sprayed with Zinc Cromate primer, sanded with 400 grit sand paper, Sprayed my color, then shot it with a clear coat. Some will say to use a vinegar solution consisting of a 50/50 mix with water. I was told that after I had painted my boat. Good luck to you.PS This is probably going to be moved to the Boat section.
  #3
Old April 9th, 2003, 10:17 AM
ehenry ehenry is offline
mjcombs, you'l probably get more replies in the boats forum instead of this forum. BUT, I'll tell you how i painted mine. I sandblasted the hull then primed it with a two part acid based primer that you can get at any autobody supply store. Just tell them what you are painting. Then you can shoot what ever color you want on it.
  #4
Old April 9th, 2003, 10:29 AM
FlyBoyMark FlyBoyMark is offline
Ensign
From my earlier post:Aluminum must be bare and all corrosion removed. (including seams...) use alumiprep, then alodine, dry, self etching zinc chromate, let cure for several days, then spray good high quality poly paint with hardner.If ya jus want a quickie cheap job: Cheap automotive enamel and use 3M pad to scuff up and paint two coats.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Aluminum boat paint help rick3b Boat Restoration and Building 6 July 19th, 2009 12:18 PM
Aluminum boat restoration, paint? kiwi1982 Boat Restoration and Building 7 December 28th, 2005 12:45 PM
paint my 14 aluminum boat help!!! caldog101 Boat Restoration and Building 0 April 24th, 2004 06:27 PM
what paint to use on aluminum boat? ironcitymadman Boat Topics and Questions (not engine topics) 10 August 28th, 2003 07:22 PM
Aluminum Boat, Paint job? Karl Seibel Boat Topics and Questions (not engine topics) 15 March 25th, 2003 07:03 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
