Last 4 years replaced, power pack (3 times) for running rough, then eventually no spark, have just replaced plugs and power pack again,went for test run approx 30miles, stopped motor for a while then started , with no problems, sat on 3500 revs 20kts went to adjust trim on pushing switch for up or down motor started to miss/ loosing power, vibrating, releasing switch motor picked up again.Put into nuetral/idle adjusted trim/tilt with no veriation on motor, went to 4000 revs adjusted trim again motor was badly cutting out maybe only on 2 cyclinders, have checked wiring, battery terminals (not wing nuts). Volt gauge gets to 14.6v at 4000 revs, taco is working all the time except on cutout of course, checked all plugs and connections all okay. p.s. motor was also missing intermittently without adjusting trim but only sometimes and was not vibrating badly. Help please!!!!
