  #1
Old December 2nd, 2007, 10:32 PM
Benny1963's Avatar
Benny1963 Benny1963 is offline
Default evinrude 150 head swap
found that one of my heads. is warped mr hadley said that the most i can surface .is 010 put feeler gauge under and got 013 at worst spot
wanting to know if i can go a little firther if machineist cant get it with 010
and use thicker head gasket.like the low octane part on brp site.
or if some one knows if 175 or 250 heads will work
or possibly xp heads .would like to save head its in perfect condition
other than warped / or should i leave it to machinest/ or cut 010 and use
thicker head gasket on one side other side is good with new gasket and ex gaskets are new .
thank yall very much. BennyB
__________________
Benny B
  #2
Old December 3rd, 2007, 08:32 AM
Dhadley Dhadley is offline
Location: Port Charlotte FL (almost -- its coming along)Never mind - it'll never be the same
Default Re: evinrude 150 head swap
If it's warped that bad you can cut it and use the thicker gaskets. If it were mine I'd get a set of 150 XP / GT heads. They have an excellent swirl pattern. Any 149 cid V6 crossflow set of heads will work. (Keep the heads in a set) The 175 crossflow heads will work, the 175 looper heads will not work. None of the 250 heads will work.
  #3
Old December 3rd, 2007, 04:33 PM
Benny1963's Avatar
thanks d hadley im going to have the head cut if it clens up at 010 i will run factory gasket if it is slightly more i will go to the thicker head gasket.
looked at what was going to be a set of xp heads but the part numbers were for a 149cid crossflow 1984 so i didnt buy them .and it seems the xps have gone the way of the old 375 horse chevy heads very hard to find
thank you very much for your time
Bennyb
__________________
Benny B
  #4
Old December 3rd, 2007, 05:31 PM
Before you go any further make sure the set you have is a matching set. The port head will be one number lower than the starboard head. IE -- port 123456 and starboard 123457.
If you cut one, cut both.
  #5
Old December 4th, 2007, 07:21 AM
emdsapmgr emdsapmgr is online now
To save yourself some headaches, I'd start looking for a set of replacement heads. D. Hadley is right, there are tons of older crossflow heads still around. They made some really great ones in the late 70's. Also some good ones on the 150XP/GT engines in the late 80's. You should see some performance improvement. You see them on Ebay frequently-just be persistent. As he mentioned, be sure you get heads for a small bore crossflow.
  #6
Old December 4th, 2007, 07:29 AM
Benny1963's Avatar
took heads to machine shop 007 was the worst . the other head was good but i had surfaced 003 they took 008 oof of the right head .will use new standard size brp gaskets , but will not stop looking for some good xp heads .
thanks to both of yall for your help .it means a lot to have someone to
recieve info from
any time anywhere . Bennyb
__________________
Benny B
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
power head swap? johngwp Johnson & Evinrude Outboards 3 July 22nd, 2006 09:07 AM
350 to 305 OMC Head Swap DangerDan Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 3 July 16th, 2006 02:59 PM
evinrude 35hp power head swap what66 Johnson & Evinrude Outboards 8 March 25th, 2005 07:28 AM
cylinder head swap chavonbravo Johnson & Evinrude Outboards 2 February 21st, 2005 03:02 PM
1984 to 1971 Evinrude 50HP power head swap spam0012 Johnson & Evinrude Outboards 1 July 24th, 2003 02:16 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
