92 200gt no fire
westex
Hi, first post here. I have a 1992 200 gt that has no fire. it ran when it was put in storage last year,starting battery went bad,replaced it now it has no fire on all cylinders.disconnected the kill at the pack ,still no fire. disconnected the yellow wires from stator, still no fire.stator ohm'ed good but no voltage from stator 150 or 12 volt any help is appreciated:)
HighTrim
Re: 92 200gt no fire
When you say no voltage from stator 150, Im assuming you are referring to testing the brown wire to the brown/yellow wire. Its resistance should be 900 to 1100 (35 amp) or a DVA reading of 150 V or more connected. WHen you mention the 12 V, were you testing the Orange to Orange/Black , it should be 12 to 24 V connected. Use a comparison reading as different brands of meters will give different readings. The typical range is 1M to 5M ohms. As long as you have approximately the same ohm reading on all tests and the correct output with the DVA meter, the Timer-Base should be good. The exception would be if one of the scr?s inside the Timer-Base is breaking down while the engine is running. This can be found indexing the flywheel and checking the timing on all cylinders. If the readings are off, reverse the meter leads and retest to see if the readings are corrected.Also check the cranking RPM. A cranking speed less than 250-RPM will not allow the system to fire properly.
1730V
Are you sure the kill lanyard is attached? Manually press the button in and try again.
westex
thanks HIGH TRIM you are correct about the color code of the wire and the ohm range is correct the timer base ohm and voltage is good, but no stator voltage, and one volt at coils. what needs to be replaced?
