How does one flush their inboard-outboard system?
Faerbairn
1979 Mercuiser 140hp, Serial # 5332813
Mercruiser 140 Outdrive # 5337746
My problem: Rusty deposits coming out of my cooling system. I want to run some sort of product thru my system to clean out all of the deposits. Does anyone know of a simple way and a good product to do this?
Thank you for your help.
Haut Medoc
Re: How does one flush their inboard-outboard system?
None that I know of.....
JustJason
raw water or closed cooling?
Faerbairn
Raw water
KRS
Banned
I'm not aware of any product that you can pour in that will remove rust.
cooter2506
IMO I would pull the riser and exhaust manifold for a thorough inspection. Sounds like they are flaking apart. Probably due for a change.
JustJason
nothing you can really do for rust. its normal and is going to happen. West has a "salt treatment" kit for like 40 bucks that you hook up inline with the muffs. may not hurt to try it.
if the manifold/riser is above 160 in the water then it's time to change those as well.
