Outboard Motor Stand plans
superflydudebike
Need to build a simple functional wood motor stand to hold two small outboards (6 and 9.5 HP). Any links to plans or description of simple design. Thanks.
Chris1956
Re: Outboard Motor Stand plans
With those small motors, you can use a simple sawhorse. Put a cross piece of wood between the legs of the 'horse, to hold the gearcase vertical, if necessary.
Hashi
I used to use an old hand truck I got from a garage sale ($10.00) and had a friend weld a steel plate on it. I can move the motor around with ease. You can also check Ebay or Craigslist for used hand trucks built for outboards.
bassboy1
deejaycee made a rollable stand out of an old push mower, by welding 2 pieces of steel to the mower deck, and putting a crossbar to attach the outboard to.
deejaycee_2000
jonb14
After viewing other OB stands, I built my own today.
Holds both my Evinrude 9.5HP and Trolling Motor like a champ!
Thanks for the tips ...
