  #1
Old December 1st, 2007, 04:33 PM
smilesssss smilesssss is offline
Default Change impeller 115hp 2002 mercury
pulled the four nuts that hold the lower unit and the nut by the impeller but cant get the lower unit to drop...what else am I missing?
  #2
Old December 1st, 2007, 06:24 PM
Don S's Avatar
Don S Don S is offline
Default Re: Change impeller 115hp 2002 mercury
__________________
Don S.
Why is there never enough time to do it right the first time,
But always enough time to do it again?
Please, NO PM's (Private Messages) regarding boat/engine problems.
That is what these forums are for.
Only forum/moderator issues will be answered in PM's.
  #3
Old December 2nd, 2007, 10:18 AM
Texasmark's Avatar
Texasmark Texasmark is offline
The new gearbox that came out in about '90 gives you access to all 5. Prior to that, in that hp range, they hid one under the trim tab and to get at it you had to remove it.
Mark
  #4
Old December 3rd, 2007, 12:29 AM
Quote:
thanks Don but I did that and still cant get if to come off. Any suggestions when its stuck?
  #5
Old December 3rd, 2007, 01:00 AM
HONKER1 HONKER1 is offline
Send a message via AIM to HONKER1
Wink Re: Change impeller 115hp 2002 mercury
I have the same motor, and this winter I will be also changing the water pump, so this thread is of interest to me. I have the Mercury repair manual and have been doing some reading, but I have never attempted to do the repair. Still getting my nerve up.
I did notice that on the re-install that they call for a small bead #116 RTV 587 Silicone Sealer located by the water pump cover assembly. Again, I am no expert, (and waiting for the pros to jump in ) but is it possible that this old silicone is holding this from dropping down. Maybe a light tap with a piece of wood, and it will drop.
  #6
Old December 4th, 2007, 10:48 AM
Texasmark's Avatar
The only thing in there is the splined drive shaft, splined shift shaft, and a water tube from the water pump....plus a small water pickup hose on some engines.
Probably the drive shaft is stuck and needs some coaxing. Need to be careful banging on things as the horizontal alum parts are brittle and can be bent or broken off by banging on them.
Might go to the archives and look up some successful tricks others have tried. Might give "Laddies" a PM as he used to be a Merc mechanic and should know.
Mark
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Mercury 3.9hp won't pump after impeller change Wiggy Mercury & Mariner Outboards 5 September 8th, 2006 06:55 PM
Impeller change Mercury 40 OB mooregecko Mercury & Mariner Outboards 8 June 8th, 2006 06:48 PM
Plug change on Evinrude 115hp 2002 Ghost Johnson & Evinrude Outboards 1 March 22nd, 2004 12:22 PM
Impeller change in 25 hp Mercury Tom H. Smith Mercury & Mariner Outboards 6 July 29th, 2003 10:28 AM
78 mercury, no neutral after impeller change :( jsp123 Mercury & Mariner Outboards 1 June 4th, 2003 06:02 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
