  #1
Old December 1st, 2007, 01:26 PM
DennyMac DennyMac is offline
Default Evinrude Starting Problem
I have an Evinrude 1992 40hp outboard, model 7E40ELEN.
The starter drive "whirs", but doesn't raise up to engage the flywheel. I've cleaned the battery connections and checked the starter fuse.
Could this be the solenoid? Is there an easy way to check, or just replace?
What about the starter motor? How do I check? Am I better off just to replace the solenoid, and go from there?
Thanks!
  #2
Old December 1st, 2007, 02:16 PM
flabum flabum is offline
Default Re: Evinrude Starting Problem
Sounds like a few things it could be.
1) Battery condition. A weak battery will not produce enough power to spin the starter fast enough to raise the bendix. Load test the battery. A local auto parts store can do this for you.
2) Stuck bendix. Check to see if you can raise the bedix by hane with only spring pressure giving resistance. Lightly grease the worm gear under the bedix and shaft with graphite, lithium or any other light grease.
3) Poor battery connection. I usually put a battery load tester on the battery connections at the motor to test this. If it holds a load at the motor, the cables are good.
4) Poor connection in the starter solenoid. Take two BIG screwdrivers and cross the two big studs on the starter solenoid. If the starter spins the bendix up and spins the motor, the solenoid is bad.
5) Bad starter. Get a known good battery (like the one in your car) and a set of jumper cables. Hook the ground to the frame of the starter and touch the positive to the stud on the side of the starter and see if the strter will spin up and engage the motor. If not, get the starter rebuilt or get a new one.
  #3
Old December 1st, 2007, 03:01 PM
Thanks flabum,
I cannot raised the bendix by hand. Is it best to load test the battery before proceeding? I had trickle charged the battery, so it should be good, right?
I'm thinking you are in Florida, as I am.
Thanks.
  #4
Old December 1st, 2007, 04:25 PM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
i have the same motor: to raise bendix, turn it the opposite way.
90% of starter problems are bad connections. remove and clean both ends of the battery cables, so that they are shiney, also the cable from the solenoid to starter. check for nicks in the cables. and make sure the connectors are on the wire good. the cable tend to corrode from the inside out, if nicked, corroded wires, and connections, heat up and cause resistance to the follow of electricity, thus the starter doesn't get enough. you can also take jumper cable pos battery post to large post on starter. with a good connection, the engine should spin. then if the starter is good clean everything and retest. then trouble shoot solenoid. starters can be rebuit at a starter/alternator shop, much cheaper than a new one.
also have the battery load tested at the auto parts store, free, i've had new batteries go bad
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #5
Old December 1st, 2007, 04:28 PM
Silvertip Silvertip is offline
If you can't raise the bendix by hand, you have isolated the problem. Its obviously seized to the starter shaft. Remove the starter, remove the bendix, clean up the shaft and install a new bendix. DO NOT replace the solenoid. It is not the problem as it obviously spins the starter. The starter is also not likely the problem. It makes no sense to do electrical tests when you have identified a mechanical issue.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Evinrude starting problem ark Johnson & Evinrude Outboards 4 April 5th, 2004 04:17 PM
Evinrude 2hp starting problem Rdalton Johnson & Evinrude Outboards 3 May 19th, 2003 10:43 AM
Evinrude (79) 115 HP Starting Problem 115999R Johnson & Evinrude Outboards 0 May 7th, 2003 07:24 AM
225 Evinrude Starting problem MakoMike Johnson & Evinrude Outboards 18 February 15th, 2002 04:24 PM
Evinrude Starting Problem StuFraser Johnson & Evinrude Outboards 1 February 10th, 2002 06:11 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
