Water in oil
sebas54
Hi, I have a 1987 gmc Merc. I found that there is water in the oil. I have posted an earlier thread stating all my problems. Well, it overheadted...plugs had water on them...checked the heads, there not cracked... I just bought new gaskets, mainfolds, risers, spark plugs, and I had the heads done. I have been assembling the enginge back together and changed the oil. While changinging the oil I saw water, about a half court, it was in the filter also. Am I doing the right things or have I overlooked something? I am scard that I may have another problem that was overlooked due to the water in the oil. Thanks.
Re: Water in oil
Ayuh,............
It's hard to say What you've got going on,.......
You went to Rippin',+ Tear'n before you did enough Diagnostics..............
Now all you can do is put it Back Together,+ If there's still an Issue,........
You can do the Testing Then..........
