  #1
Old November 30th, 2007, 01:48 PM
TheBish TheBish is offline
Exclamation Mercury 70hp - Steering Question
I have a Mercury 70hp outboard attached to my Simms Super Vee Speedboat.
The steering cables appear to be in good condition and functioning.
Unfortunately, the engine does not move to port or starboard when I turn the wheel.
It is almost as if the engine is locked in place.
Does anyone know if there is some sort of locking pin that I need to release?
Also, does anyone know where I could download a user manual?
Thanks in anticpation of any advice that can be offered.
The Bish
  #2
Old November 30th, 2007, 01:52 PM
Chris1956 Chris1956 is offline
Wink Re: Mercury 70hp - Steering Question
Bish, The motor should swivel on two bushings. If you cannot swivel the motor by hand (steering cable disconnected), those bushings are likely corroded and frozen. You can try some penetrating oil or heat on the bushings, and see if it will loosen up, or disassemble the motor (remove powerhead and lower unit), and clean 'em up.
If you have a single push/pull steering cable, you will need to unbolt it from the motor and then try to swivel the motor.
  #3
Old November 30th, 2007, 02:02 PM
Thumbs up Re: Mercury 70hp - Steering Question
Many thanks for your swift and helpful response Captain Chris. Been scratching my head all afternoon looking for a locking nut!
  #4
Old November 30th, 2007, 02:06 PM
Don S's Avatar
Don S Don S is offline
Default Re: Mercury 70hp - Steering Question
What year is it?
__________________
Don S.
Why is there never enough time to do it right the first time,
But always enough time to do it again?
Please, NO PM's (Private Messages) regarding boat/engine problems.
That is what these forums are for.
Only forum/moderator issues will be answered in PM's.
  #5
Old November 30th, 2007, 02:21 PM
Not exactly sure about the year. I reckon it is about 10 years old.
  #6
Old November 30th, 2007, 02:51 PM
Don S's Avatar
Well, if it's between an 87 and 93, you are going to need Mercury service manual #90-13645--2. Merc didn't make a 70hp 3cyl after that, it changed to a 75.
Might try ebay or your local Merc dealer to get one.
The owners manual won't help with the steering.
One question, when you turn the wheel, does the rod on the end of the steering cable that goes thru the aluminum tube move?
You may just have a broken steering cable, or faulty helm. The motor bushings may be fine.
To check your steering, in the diagram below, remove the nut from the link rod where shown, and remove the link rod from the cable end. Then see if the motor will move back and forth.
Also try the steering and see if the rod moves inside the motor tube.
__________________
Don S.
  #7
Old December 1st, 2007, 05:04 AM
Dear Don,
Thank you for your advice thus far, it is very much appreciatd.
When I turn the wheel the steering cable does come under tension, all the way to the engine, but the plate that goes into the engine is stuck solid and will not move at all.
The engine itself has a little give into it, left and right but does not freely move.
My steering is different to your diagram as my steering cables have two pulleys by the engine that attach to a metal plate that goes into the engine. It is this that does not move at all.
Apologies for the very 'un' technicl language,I am very much a novice.
Also the engine is a two stroke.
Many thanks.
The Bish
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1969 Mercury 80HP Steering question Newbe15132 Mercury & Mariner Outboards 12 September 18th, 2007 07:50 PM
1974 Mercury Steering or tilt tube compatible with new teleflex steering kit? mike4901 Mercury & Mariner Outboards 1 August 22nd, 2007 11:01 AM
90 Evinrude 70HP VRO - repaint engine cover & steering question... KenJr Johnson & Evinrude Outboards 6 May 27th, 2006 05:04 AM
1962 Mercury 700 70hp question(s) Porto Mercury & Mariner Outboards 8 June 8th, 2005 08:44 PM
mercury steering link arm question GOTFIVE Mercury & Mariner Outboards 3 February 9th, 2005 06:04 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
