I'm upgrading my 1973 Cobalt with a 888 setup to the following.
Alpha 0ne 1980's Gimbal housing assembly with side mounted sender and limit switch.
I want to replace the trim pump and cylinders. My 888 has a reverse lock out/trim sender switch mounted on the inner transom plate. I've read that the new trim pumps have this feature built into them. How is this activated. I can't find any description on the web. I figured it would have to be a micro-switch to lock the reverse portion of the pump to prevent the outdrive from rising when in reverse conditions. Can any one shed some light on this subject?
Regards and thanks in advance.
Mike
Mike
