  #1
Old November 29th, 2007, 09:58 PM
Redneck Redneck is offline
Default Yamaha 4 stroke timing belt change?
I acquired a boat with a 40 hp 4 s year 2000 model Yamah motor. I was told it only has 15-20 hours at most. The person has no reason to lie about this, as we bartered for the boat and I came out extremely well on this trade.
I have had tyhe carb issues twice, first from it sitting up with gas in it, and again when phase seperation happened again in the tank.
How do I know if the timing belt needs changing? From what I have read if it goes there goes the whole motor!
Is there a way to check and know if it is OK?
  #2
Old November 29th, 2007, 11:14 PM
rodbolt rodbolt is offline
Default Re: Yamaha 4 stroke timing belt change?
yep
the maint schedule is 1000 hours OR 5 years whichever occures first.
its just to cheap and easy to fix it BEFORE it breaks.
however the F and T 40 motors are clearence engines. if the belt breaks the engine simply stops.
  #3
Old November 30th, 2007, 01:31 AM
drewmitch44's Avatar
drewmitch44 drewmitch44 is offline
Quote:
Originally Posted by rodbolt View Post
however the F and T 40 motors are clearence engines. .
Does that mean they are on SALE? Im not sure what you mean by clearance engine. I assumed you ment they are on clearance like marked down in price. Thats a good thing!
  #4
Old November 30th, 2007, 01:41 AM
AGENT 37 AGENT 37 is offline
Valves get smashed by pistons when the timing belt breaks on interference fit motors. Some motors are designed where there can be no contact between pistons and valves regardless of crank/cam position line-up. I think that clearance and interference fit are being used interchangeably.
  #5
Old December 1st, 2007, 08:25 PM
andymach23 andymach23 is offline
Rodbolt
Is the 1998 F80 also a non-interference engine?
Cheers
Andy
  #6
Old December 2nd, 2007, 01:17 AM
the F80 is an interference motor, if the belt lets go odds are high it will take the head with it.
  #7
Old December 2nd, 2007, 05:15 AM
Thanks Rodbolt,
I just had a look in my service manual for my 2004 F40. Replacing the timing belt looks easy enough. Just line up the timing marks and slip the new belt on.
I will be getting the service manual for the F80 when I get my new boat. Is the timing belt replacement on the F80 (1998) the same deal?
My Yamaha dealer has quoted me 5 hrs labour and 300 pounds ($600) to do the timing belt and water pump (including parts).
I have done a water pump in the past and would tackle a timing belt if it's an easy job.
Just curious.
Andy
  #8
Old December 2nd, 2007, 09:38 AM
5 hours?
in five hours,barring any stuck fasteners due to salt water, I could probaly do 3 and be almost done with the 4th.
even a slow tech should be able to change a belt and a water pump in less than 2 hours on the F80 or the F40.
it requires flywheel removle to change the belt on most but its not hard with the correct tools and a pre-read of the service manual to gain some knowledge of what your gonna do.
a quality flywheel holder and a quality harmonic balancer puller make the job a lot easier.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
when to change timing belt on 500 50hp dave37 Mercury & Mariner Outboards 4 October 25th, 2007 08:18 PM
timing belt change out jwilkey84 Mercury & Mariner Outboards 2 July 12th, 2007 09:07 PM
Yamaha F25ELHZ 25 HP four stroke timing belt oceancpt Yamaha & Suzuki Outboards 7 March 26th, 2006 02:12 AM
Tensioning timing belt 50hp 4 stroke Zerex Mercury & Mariner Outboards 7 October 30th, 2005 06:38 PM
Volvo - Timing belt and bearing change BrianG Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 0 July 1st, 2002 08:19 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
