  #1
Old November 27th, 2007, 09:36 PM
bostonpilot bostonpilot is offline
Default Lower unit oil leak - 15hp Mariner
Hi,
It appears as though the lower unit on my 15 hp mariner is dripping oil from around the prop. The two new oil seals and O-ring are easily purchased, but I am wondering how much of a nightmare I am facing to replace them. Any advice?
From looking at my repair manual's description, it appears as though I need to go as far as pulling the bearing carrier out to replace the seals and O-ring. Once I do that, have I taken on additional work, or can I stop and that point and then just reinstall the parts that I removed?
Also, the book references a special tool (p/ 91-13664) to remove the bearing carrier, with an alternate method of using the thrust hub. How needed is the tool?
Thanks!
  #2
Old November 28th, 2007, 09:36 AM
Laddies Laddies is offline
Default Re: Lower unit oil leak - 15hp Mariner
If the carrier is not stuck the hub will usally remove it.
  #3
Old November 28th, 2007, 11:36 AM
j_martin j_martin is offline
Are you sure the oil is gear lube? It could just be excess 2 cycle oil in the exhaust.
Gear lube is sticky and very slippery, and has a unique odor.
hope it helps
John
  #4
Old November 28th, 2007, 12:26 PM
No, I don't know for sure. Unfortunately, I am handicapped by the motor being 50 miles away at my parent's house since my wife and I live in downtown Boston - I haven't convinced her that outboard repair work in the kitchen is a good idea yet.
It appears as though the unknown substance is very black, oily, slippery, and stinks. I was told it smells like dead fish when I asked, but that could be from some of the sea growth that was on the lower end when I hauled this year.
The material is weeping out from the joint between the prop and casting, aronud the OD of the prop.
What would your best guess be as to the source of the goop?
Is it likely/reasonable that oil in the exhaust would present itself there? (the engine has been running super rich lately)
  #5
Old November 29th, 2007, 12:57 PM
Most of the exhaust goes out through the propellor hub. If some goop is left in the path, it'll drip out around the prop. It's a close fit, but not a seal.
Loosen the drain screw on the LU, and let a drop or 2 leak out. If it's milky, or water, you have a bad seal and it needs to be repaired. If it's a dark, relatively clear liquid, get a drop on your finger and smell it.
Now, bloodhound, smell the goop coming from the prop. If it smells the same, it's gear lube. If it smells like burnt oil, it's probably burnt oil.
WARNING...... If you have water in your lower unit and it is allowed to freeze, it will wreck it.
hope it helps
John
  #6
Old November 29th, 2007, 02:03 PM
Great, thanks. Easy enough to do. Sure would be nice not to open up the lower end if its not needed.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Oil loss in lower unit on Force 15hp pecheux Force & Chrysler Outboards 2 October 9th, 2006 11:18 PM
15hp lower unit swap.....? phatmanmike Johnson & Evinrude Outboards 2 September 13th, 2004 09:07 AM
Yamaha 15hp lower unit problem Yamahaer Yamaha & Suzuki Outboards 1 April 8th, 2004 09:50 AM
yamaha 15hp lower unit four_wheel_madness Yamaha & Suzuki Outboards 0 April 12th, 2003 08:16 PM
Lower Unit Leak??? Doint know if I have a leak jeff7599 Johnson & Evinrude Outboards 3 April 1st, 2003 03:55 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
