Hello and thanks for stoping by.
1977 Johnson - 115HP (V4 I think) - Model: 115EL775
Here is the story: I recently purchased my first boat fairly cheaply knowing that although the engine would start, there was quite a bit wrong with the boat. Having worked through all the other problems I am now wanting to get it on the water, but I need to fix the idle first.
I am pretty sure a red-neck owned the boat prior to me, but I grew up on a ranch so fortunately I speak the language, but the throttle and drive system are the most "country riggin" I have ever seen.
1. The trottle system still ties into the Johnson Command Center (anyone have a diagram of that? Basically the Control Box - starter, throttle adjustment, drive, etc )
2. The (lower) drive cable attaches to a seperate lever on the console(I plan to fix this if I can ever find the correct cables and connections and as money allows) I will provide pictures as its kinda funny and hard to explain.
For testing purposes I set the drive system to netural
Started the motor with the "fast idle arm" pulled to the top, and the motor will start at very high RPMs, but when I lower the idle arm(even after the engine has run for a few min) to the bottom the engine will die. I want to make sure I have my idle good prior to trying to test it out on the water.
I have ordered the manual, but while waiting I thought I would ask you guys for any suggestions of the best way to tune the idle. I will include pictures of the componets etc tonight.
Thanks
Roy
Thanks
Roy
