  #1
Old November 26th, 2007, 11:54 AM
fishnpick fishnpick is offline
Default 1998 Yamaha 80 HP alarm and forward gear
Put my 98 Yam in the water this weekend. Launched fine and ran about 500 yards to dock. Alarm came on. Checked water pisser and good stream coming out. Cranked up put in gear will not get going. Shut down and loaded up. While on the trailer if you put it in reverse you can feel it go in gear and all appears well. When you put it in Neutral the prop spins without resistance as it should. When you put it in forward the prop still turns and you hear a clicking sound as if something is not meshing up. What do I appear to have ....linkage problem. Pulling cowling I saw several big dirt dobber nest that evidently came loose or were knocked loose by the linkage....could this have caused my problem. I am an amateur when it comes to Yamaha so be gentle and treat me like a baby please........I dont know much about Yamahas. What should I do first and how to go about it would help very much. Thanks
  #2
Old November 27th, 2007, 09:21 AM
rodbolt rodbolt is offline
Default Re: 1998 Yamaha 80 HP alarm and forward gear
when in fwd gear the prop will lock in one direction and ratchet in the other. its normal, the alarm is not.
however I have no clue what type of 80 HP yamaha we are disscussing so thats about all I can tell ya.
  #3
Old November 27th, 2007, 10:21 AM
Thanks for the reply rodbolt.
This is a 2 cycle 1998 80 HP yamaha. It is not oil injected one must mix the oil with the gas. I can give you serial numbers and model numbers if you need them to help me out. Thanks for the info on the prop. It does exactly what you said.....locks in one direction and ratchets in the other. Good to know that I dont have a lower unit problem. What do you recommend as a starting point to find the source of the overheat beeper? My first thoughs are that today I will hook up the muffs to it and crank it up and see if it will flush out and see if the overheat beeper comes on. I will do this and report back with my findings. Thanks for your assist. fishnpick
  #4
Old November 27th, 2007, 02:25 PM
Hooked up to muffs. Runs fine. Shifts fine. Pumping no water. I assume that the water path is clogged somewhere or the water pump is gone. It has never has a water pump put in perhaps its time???????? How can one flush the path?????
  #5
Old November 27th, 2007, 03:52 PM
Took the lower screens off and took the pisser hose off. Using compressed air I blew out the house and blew through the water chamber and out the lower screen. Did the same from the bottom up....get air from the piss hole and when you blow from the piss hole to the lower screen you get air........I can only assume that the water pump is gone. Serial and model look like this.. Yamaha C80TLRV
6HO L 351594
W Anyone got a link to detailed instruction as to changing the water pump. I have changed them on Mercs and Rudes but this is my first Yamaha....is it the same or about the same procedure...???Thanks for any replies....
  #6
Old December 1st, 2007, 01:37 PM
Replaced water pump impeller and plate...plate was good but shows some wear so I replaced while in it. Cleaned out dirt dobbers and opened all passages. Soaked and cleaned carbs while I had it at the house. It purrs like a new born kitten. Took to lake and it runs out at all speed and gets to plane quickly and easily......its back to its old self. Thanks for the input.....great site and easy to use site. fishnpick.....
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1998 Yamaha Saltwater Series 115 Alarm? batteryxsnare Yamaha & Suzuki Outboards 7 March 11th, 2007 07:44 PM
1986 Yamaha 150ETLJ No Tilt/Trim in forward gear? JSchaumleffel Yamaha & Suzuki Outboards 2 August 22nd, 2006 08:45 PM
40 Yamaha Long Shaft 1985 UK Model - no forward gear thebigman Yamaha & Suzuki Outboards 0 January 29th, 2006 03:34 AM
1998 Yamaha 200 gear fluid leak? Chuck2557 Yamaha & Suzuki Outboards 2 October 18th, 2004 07:21 AM
1998 XR6 150 heat alarm treeboy0515 Mercury & Mariner Outboards 2 September 29th, 2003 06:49 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
