  #1
Old November 25th, 2007, 10:14 PM
javiert99 javiert99 is offline
Default Yamaha 175 - Won't shift into reverse after idling / slow speed / cold
I have an older mid 80's Yamaha 175 that is being pretty strange about going into reverse. It is a 175AETO, but I believe it is the equivalent of an 175ETXK (175hp 20" shaft)
When cold, or after idling for a while, it won't go into reverse, it just grinds. If you take the cable off, it will pop itself out of gear. This is the same whether on land with the muffs on, or on the water. If you adjust the throttle cable back far enough you can hold it in reverse on the muffs. On the water with the cable on it will just grind though when cold, or after a while of idling, etc.
I found today though that after running around at a decent amount of speed, some full throttle operation and some part throttle (3k rpm or so) runs it will shift into reverse just fine afterwards.. It won't grind or complain, it just "clunks" as it does into forward and it works just fine. My throttle doesn't appear to be adjusted right as it doesn't give me much room to give it much gas, but at least it engages. After it "cools off" and you go back to idling again for a while, it will no longer engage.
Forward works fine, all the time, every time.
I changed my lower unit fluid and saw some metal on the magnet, and the fluid didn't look too great, but I saw no chunks or anything along those lines.
Can someone make some sense out of this for me? The shift shaft on the motor seems fine. It's a solid 1/4" wide, does not appear to be corroded based on the two sections I can see, not sure if it could be corroded in other areas or if this would even be related.
I just bought the boat knowing reverse was a problem (the price reflected it) but I'm trying to get an idea of where I need to go w/ it.
Thanks!
  #2
Old November 27th, 2007, 01:38 PM
Default Re: Yamaha 175 - Won't shift into reverse after idling / slow speed / cold
The more I read the more it sounds like the shift shaft, even though the two locations that are "visible" with the motor assembled (especially right above the cavitation plate) seem to be solid. Does the fact that the engine will engage reverse after some time at speed clear the lower unit of fault? Why would it engage sometimes and not others?
If I pull the lower unit and the shift shaft looks OK, should I assume it's ok in other places I cannot see it?
If the shift shaft is bad, is the stainless part standard across a certain number of years and motor series?
I have this "175AETO" and I'm not sure how to order parts for it when the time comes. It's a 20" shaft mid 80's Yamaha is all I really know.
  #3
Old December 11th, 2007, 02:24 AM
Well, I got no replies, dunno why... but I just wanted to report back that after quite a bit of searching and speaking to others I came to the conclusion that my lower unit was bad.
I found a parts motor with a blown powerhead but good lower unit for a great price and swapped my old lower unit with this one. Now I have reverse working 100% of the time, and my shift shaft looks like it should give me years of service based upon inspection.
All is well once again in the land of my Yamaha.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
8hp Yamaha Won't run just above idling speed at full throttle publicbar Yamaha & Suzuki Outboards 3 September 3rd, 2007 09:32 AM
Bad idling, jerky ride at slow speed rizy1976 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 17 June 9th, 2006 12:46 PM
Slow speed in reverse: Dr. Rich Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 7 September 20th, 2005 11:31 AM
'91 225 Yamaha runs only at slow speed wasted-wanderer Yamaha & Suzuki Outboards 3 July 28th, 2005 06:23 AM
Yamaha 50 hs. slow speed, high rpms. Joe Hernandez Yamaha & Suzuki Outboards 2 March 19th, 2003 05:10 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
