  #1
Old November 25th, 2007, 08:42 PM
papawoulfe papawoulfe is offline
Default 1990 Yamaha 150 slow mode and alarm.
My yamaha 150 runs perfect at mid range at below 30MPH. When I get to full speed at above 40 MPH the alarm comes on and the engine speed drops. If I turn the motor off and let it rest for a minute, I can start it back up and the motor runs fine. Got a water stream at the drain hole. I have made repairs to the wires to the auxilary tank pump. The auxilary tank pump motor is running when the ignition switch is turned on. The motor only has 650 hrs,
  #2
Old November 25th, 2007, 11:55 PM
rodbolt rodbolt is offline
Default Re: 1990 Yamaha 150 slow mode and alarm.
your visual indicates on the tach will tell you if the alarm is overheat or low oil level in the engine tank. the remote tank is not monitored with any alarms other than a yellow visual on the tach.
  #3
Old December 3rd, 2007, 06:36 PM
JUSTINTIME's Avatar
JUSTINTIME JUSTINTIME is offline
if you need the dealers troubleshooting guide on the oil system shoot me an email
__________________
HUMAN BUILT = HUMAN FIXED
CERTIFIED MARINE TECH
  #4
Old December 5th, 2007, 09:29 PM
angjackson29 angjackson29 is offline
I have a Yamaha 115 4 stoke with gas smell in oil. When idling it surges rpms a little. any clue where gas is coming from?
  #5
Old December 6th, 2007, 03:11 PM
JUSTINTIME's Avatar
fuel pump
__________________
  #6
Old December 6th, 2007, 07:26 PM
after lots of free advise, someone suggested that it could be thermostat making it run too cool ie calling for more gas? could you elaborate about fuel pump?
thanks for your reply
  #7
Old December 6th, 2007, 09:04 PM
vmaxjay's Avatar
vmaxjay vmaxjay is offline
Hmm...The only time mine has ever went off was when the oil pump quit working and one other time when I got some grass in the water pick ups... How many #'s of water pressure do you have at 30+ mph? Also... did you check your oil reservoir (the one on the engine) to check the oil level? It has to be withing those 2 lines or it will go off.
__________________
Release 20 / Bob's Hydralic Jack Plate / Yamaha V Max 2.6 Liter / Power Tech 22" 3 Blade SS Prop
http://img.photobucket.com/albums/v8...a/DSCF7606.jpg
  #8
Old December 7th, 2007, 05:19 AM
JUSTINTIME's Avatar
it be either t stat or fuel pump
__________________
  #9
Old December 13th, 2007, 08:45 PM
Talking Re: 1990 Yamaha 150 slow mode and alarm.
It was the t-stat stuck open,changed it and the oil and motor is running fine.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
93 Yamaha in SLOW mode 22Angler Yamaha & Suzuki Outboards 2 September 2nd, 2007 10:26 AM
SLOW MODE ??? droutte Johnson & Evinrude Outboards 2 August 29th, 2005 01:52 PM
SLOW mode... What is it?? TBarCYa Johnson & Evinrude Outboards 3 August 9th, 2005 08:06 PM
1990 70hp Overheat Alarm and SLOW Mandoman Johnson & Evinrude Outboards 4 November 10th, 2003 01:34 PM
25 Johnson Alarm & SLOW mode PAULMN Johnson & Evinrude Outboards 9 July 15th, 2003 07:12 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
