distributor cross compatible
krisnowicki
I have my old 350 out. I am swapping my 83 350.. for a crusader 350 I have taken all the advice on here I ordered the alignment bar and the new coupler because of the smaller crankshaft. The question I have today is ... My distributor set up on my boat is just a 2 wire system that bolts on the front of my dist. labeled + and -. The distributor that came with the crusader has two plugs. ( neither is HEI) So i am wondering can I use my old Dist on the new boat? If not where can I get the plugs to make this wiring work? Almost there and I cant wait. I will make a post with pics of the process when done.
Re: distributor cross compatible
Ayuh,............ Sure Can.......
