  #1
Old November 22nd, 2007, 09:01 PM
maxum247's Avatar
maxum247 maxum247 is offline
Default 89 maxum center console
These are pictures of the progress of the center console conversion that I have been working on.The boat is at the point were I can try it out to see that things are placed as I would like them. Had some nice days this week, but work got number one priority.
This first picture is of the surround going on and the second is of the connection of the two glassed together. Next picture shows the rear seat cut for the controls to run thru. The console has a seat built in the front. The back is open for storage,battery or whatever the need. The controls were recycled from the bowrider version, so there not a perfect fit for the console.Took some tinkering to get them to fit and work properly. Right now the wiring for the console is run on top of the deck. I am doing this on purpose. When the console is were it needs to be then I probably will put them under the deck, but for now will cover them with a peice of plastic pipe split down the middle to protect them while trying things out. Gauges and switch panels were also from bowrider console. The side view of the console shows the seat and you can see that the shifter needs a little work on the wiring. Originally the shift sat at a different position than it does now, cables ran along the side of the boat, now they run up from the floor, so in order to get the shift range right I'm going to have to do a little testing to get it in the correct position again. Shifter has a detent that is designed as a saftey, so the boat can't start in gear. Once I've got it down I will cut in a new saftey detent.
The last picture is a general view of the boat as finished to this point,next will be to glass in the cut out for the cables thru the back seat. After that it will be on to building the bow cap and washboards. Not one hundred percent sure how I'm going to do those, have several ideas. Will post more on this as I get things done.
The little tri hull in the background is a 12 footer not sure who built it. It is fiberglass, probably from the 70's but not sure. It's about three and a half feet wide. Sold a friend a fiberglass 16 foot plywood skiff with an 8 hp briggs and stratton electric start outboard that I built using a regular lower unit with a blown power head. Used it three years before I sold it, made a great motor for trolling for rock fish. putt, putt, putt.
The boat had been backed up on by a truck while laying upside down in the yard. The bow was kind of layed open like two halfs of a sandwhich, about a foot or so back from the bow. Brought it home and in time repaired the bow and put in a new stern. Very stable for a little boat, Family used to load that little thing down, throw on the 24lb thrust trolling motor and head to the sand islands camping. Have had it for a number of years now, thought about selling it once, but while looking at it, thought that would make a great hydroplane. Cut the bow section back abut five foot split it more or less down the middle, move the two peices outward to use as the sponson's, a little boxing and patching and a lot of sweating I would have a great play toy.
Happy Thanksgiving!
  #2
Old November 22nd, 2007, 09:37 PM
salty87 salty87 is offline
Default Re: 89 maxum center console
that's nuts and awesome, all at the same time.
how did you cut the topcap fiberglass so good?
  #3
Old November 22nd, 2007, 09:59 PM
maxum247's Avatar
I have to be honest it took a couple of tries. But I used a jigsaw with a coarse blade, it didn't really take all that long. After that suited up and went to town with the 4 inch grinder.
  #4
Old November 24th, 2007, 05:54 AM
SFT2 SFT2 is offline
By any chance do you have any pictures of tearing out the old deck and putting in the new? I'm about to put a new deck in my 89 Maxum and would really like to see what I'm working with before I get started.
  #5
Old November 24th, 2007, 10:14 AM
maxum247's Avatar
I have this drawing of the unitized construction used during that time.
My maxum was 20ft as a cuddy cabin, I can tell you that once you get back to the splashwell it's a bear if you have to tear any of the framing out. Take a look at the drawing. Gas tank is far enough back under the framing that you have to rip a good portion of the framing out to get the tank out if you need to. Right or wrong I chose to not replace that area of the floor for the time being. The stringers are about 2 foot apart mine were glassed and solid, the plywood cross bracing that you see in the drawing was gone. Not much trouble to put back. I can't remember if the hull had a lip along the edge for the floor to rest on or not, but you'll know once the floor is removed. I raised my floor 3 1/2 inches so that I would have more width across the boat to make use of. Made a big difference in room. Cuddy's are deeper sided so I had room to play with the height. Hope this will help! maxum
  #6
Old November 24th, 2007, 12:06 PM
drewmitch44's Avatar
drewmitch44 drewmitch44 is offline
Is that a suzuki motor in the garage in the background of the first picture? I like what you are doing i think im going to be doing almost the same thing with me sea ray 180. I like the steps you are taking. Do you have a shareaproject page? Im just curious because like i said im going to be doing almost the same thing to a closed bow boat. Its not as big as yours but it is a great hull for choppy and rough water. I also think that I am going to be able to lighten it up a lot with the work im going to do on it. Its a closed bow now that i want to at least open up to a bowrider for more room. But im at the point where if im going to do it i might as well make it into a center console. Thanks for your pictures id like to see more if you have them. You can see what im going to have to work with if you click on my shareaproject link at the bottom of my post. My parrents are letting me use their garage this winter for my restoration so im excited to get started. I moved the boat over there the other day and now i cant wait to start stripping it down. Also where did you get your center console? I was thinking about making my own out of ply and glassing the whole thing. Everything im going to be doing, i want to keep weight down as much as possible. Thanks again for sharing and it looks great!
  #7
Old November 24th, 2007, 12:53 PM
maxum247's Avatar
Morning!
No, just clutter from working on the yaucht. Looked at your project nice looking hull design. I don't have a project page, new to the computer world.
Seems you have the right attitude to go far take your time and work safely. As I stated in my last post work outside as much as possible fiber glass dust is nasty stuff. And never work without breathing protection.
Built the console from 1/2 inch marine plywood that was recycled from a realastate sign that was thrown away. If you decide to build your own console not hard to do. Be sure and have your boat level on the trailer, you may need to cut the bottom of the console a little on the bottom so the console will sit up straight but you'll know when you place it in the boat.
Did loose a fair amount of weight when I removed the cuddy cabin probably around 300 lbs in my case. If you go center console you will gain more room over going bow rider. Lost most of my project pictures awhile back, what I've posted is pretty much it for now, plan to post the washboards and bow cap in progress at some point in time.
Nice talking to ya!
  #8
Old December 4th, 2007, 12:55 AM
maxum247's Avatar
I haven't given up on the center console project, just been busy and undecided how I want to continue. Right now I've been side tracted on a new project. I'm working on putting a riding lawn mower engine in my 12 foot try hull. As soon as I make more progress on the center console project, I'll post again.
__________________
maxum247
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Center console v dual console Kachadurian Boat Topics and Questions (not engine topics) 14 December 22nd, 2007 08:13 PM
Maxum Dash/Console Replacement pgodwin Boat Restoration and Building 0 September 11th, 2007 10:54 AM
Center console???? jimyoung Boat Restoration and Building 12 July 6th, 2007 06:32 PM
New Boat: Center Console , Walkaround, or Dual Console PAkev Boat Topics and Questions (not engine topics) 17 April 2nd, 2006 08:14 AM
Center Console - What is the best Ply? Knightgang Boat Restoration and Building 8 November 12th, 2003 06:18 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
