without removing the stop lanyard you will have to disable the ign AND fuel systems.
otherwise you may have sparks AND a chemically correct Air/Fuel mix blowing out the plug holes.
the fire ball can be funny
with the lanyard removed it disables both ign and fuel systems. you will get an alarm when cranking with the lanyard removed so it tests the horn as well.
I watched some guys light up a 150 mariner oneday
. just after I warned them and they looked at me like I was stupid, so I walked away to watch the show
and that is why with EFI the ign AND fuel systems need to be disabled when running a compression test
however a leakdown is just to quick and easy and I only have to rotate the flywheel 4 times by hand 180* at a time.
1&4 will be at TDC,only one will be on compression stroke,180* and 2&3 will be at TDC with only one at compression stroke,another 180 and 1&4 are back at TDC check the one that was not on compression stroke the last time, another 180 and your back to 2 or 3 .
no cranking no muss no fuss and if its bad I know what is leaking and where.
