  #1
Old November 20th, 2007, 10:16 PM
nmiller nmiller is offline
Angry Power Trim Issue w. 2 stroke 90 Yamaha
Just recently went to take the boat out and the power trim was not working properly. Never had any type of problems in the past. I was able to raise and lower manually, but trying to get to the bottom of the problem. When trying to use the remote trim control-I can hear a click as if it is trying to trim up or down. Initially I thought it was not getting power from the battery, but have ruled that out. Any suggestions-on troubleshooting methods? Thanks
  #2
Old November 21st, 2007, 12:18 AM
koolerb koolerb is offline
Default Re: Power Trim Issue w. 2 stroke 90 Yamaha
First question, are you sure you're getting enough power from the battery. I have a 90 Yamaha also, a few times this year corrosion at the battery terminals caused a bad connection. I was getting enough power to trip the solenoid but not enough to run the trim motor. If you're sure your getting enough power my guess would be the trim motor.
  #3
Old November 21st, 2007, 03:10 AM
isla's Avatar
isla isla is offline
Send a message via Skype™ to isla
Quote:
In addition to the suggestions already had, to give evidence directly to the motor voltage trim, the relay in order to bypass all the electrical part.
If the trim work, could be the relay cables or oxidized
__________________
Gianni
  #4
Old November 21st, 2007, 10:26 AM
lasvegaskid lasvegaskid is offline
What year is the motor? There are 2 wires coming from the trim motor. If they are the same color as mine, they are Blue & Green. Put a battery charger to them directly. One will make it will go up, reverse them it will go down. You can check the relay by putting a volt meter on the wires that go to the motor from the relay. If you have voltage coming out of the relay when you push the switch, Check the motor.
Post and let us know. Bob
  #5
Old November 21st, 2007, 05:36 PM
It is a 2003 90hp 2 stroke yamaha. Ruled out getting enough power from the battery, hooked a new battery up same results-makes the same noise-kind of a click when you try to go up or down w/ it. I guess the next step is to take look at the relayer. I looked at it-and it seem fairly easy to pop out to test the wires-it does have the blue, green wires. So your suggestion is to check the voltage on the wiring, and hook a battery charger directly up to relayer. When I took it out-I did see some corrosion, but did not do any of the testing. At this point I am tempted to take it to a shop-I am a rookie-when it comes to engine repairs. The testing seems fairly easy though-maybe that is my next effort.
Should have been out fishing vs messing w/ boat!!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Yamaha 225 4-stroke, electrical issue dswanson Yamaha & Suzuki Outboards 2 June 11th, 2007 05:12 AM
2002 Mercury 115 4-stroke Trim Issue? jeffnangela Mercury & Mariner Outboards 1 May 23rd, 2007 09:49 AM
Yamaha 2004 50 Hp 4 Stroke starting issue RiverBoy Yamaha & Suzuki Outboards 8 March 1st, 2007 07:53 PM
1992 C115 Yamaha Power Trim Click & Lost Power to Key switch/trim LA3 Yamaha & Suzuki Outboards 2 July 4th, 2006 06:18 AM
Power Trim Issue BDub Mercury & Mariner Outboards 1 April 30th, 2005 10:48 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
