Quote:
Originally Posted by Pong
I have recently bought a 2002 (barely used) Yamaha 25hp 2 stroke outboard. I want to change the spark plugs but on the engine it recommends B7 HS-10. The only thing available where I live is B8 HS --is it ok to use it or should I order in the B7? I am worried about causing any damage by using the wrong spark plug. Also, must add, this is for a boat used only on the ocean.
Any recommendations would be greatly appreciated. Thanks
The advice is to use the right spark plugs
Can uare quietly the spark plugs B8HS, since most cold does not create problems of overheating it will piston spark plugs.
Never use spark plugs with a degree heat the lowest of the instructions given in the book
