very limited knowledge when it comes to engines so I need your help.
My 1990 Johnson 60 has some trouble starting and smokes considerably until warmed up. I am not the original owner so do not know the history or past care or repairs. Typically I run this at low speeds (it is on a 20' pontoon boat).
Mechanic says the compression on cylinders 1 & 3 are over 100 and cylinder 2 is at 85. Should I care?? He mentions the VRO as the culprit but from what I have seen on this site I am inclined to disagree. He has recommended replacing the VRO as a minimum and suggests rebuilding the engine is in order (something about scoring in cylinder 2). Any suggestions will be much appreciated.
Thanks
Thanks
