h20_hooked
- Sep 26, 2007
- 5
1974 Century Raven 200, 307ci OMC I/O,
Want to replace my propeller but the drive pin (3/8" dia?) will not come out.
The drive pin is pressed through a collar into the propeller shaft retaining the thrust washer, propeller.... Looks simple enough to replace ther prop but the drive pin has been kicking my butt!
I've tried tapping it out with a steel rod, but don't want to damage anything else by hammering too hard.
Also heated the collar/shaft (other than the pin), but that didn't help.
Been spraying with a 'knock out' agent (forgot the brand name) to loosen, but pin is rusted pretty bad.
Anyone know the proper way to remove the drive pin?
Ideas or suggestions are greatly appreciated?
