  #1
Old November 18th, 2007, 10:38 AM
Redneck Redneck is offline
Default Yamaha 4 strokes not to idle?
I know someone who has a 115 4s Yammy and he says he almost ruined this motor because he idles about 50% of the time. He fishes some rocky flats in N Fla gulf.
I thought the 4 strokes were tailor made for idling??
  #2
Old November 18th, 2007, 01:26 PM
JB's Avatar
JB JB is offline
Default Re: Yamaha 4 strokes not to idle?
If he almost ruined his engine it wasn't because he was idling 50% of the time. There must be other factors, including the possibility that some wrench, or wannabe wrench, had to sound knowledgable and didn't have anything sensible to say.
__________________
RED SKY at night. . .
JB
  #3
Old November 18th, 2007, 08:30 PM
JB are you saying it's Ok to run these 4 strokes on idle a lot? I have a 40hp Yammy 4 s and I fish the same waters and idle a lot too.
  #4
Old November 18th, 2007, 08:49 PM
JB's Avatar
JB JB is offline
If extensive idling harms an EFI 4 stroke there is something else wrong. I don't believe there is that sort of bug in Yamaha's firmware.
The final word on this should probably come from rodbolt.
I often ran my Suzi DF70 at idle for hours on end.
__________________
JB
  #5
Old November 18th, 2007, 10:47 PM
1730V 1730V is offline
What does the manual say? What does Yamaha say? Call them.
  #6
Old November 19th, 2007, 08:33 AM
I got more info. The motor was not getting hot enuff. The pistons weren't expanding enuff, and allowing gas into the crankcase.
"Making oil". He was running less than a 1000 rpms a lot!
  #7
Old November 19th, 2007, 08:40 AM
JB's Avatar
JB JB is offline
Okay. Making oil makes sense. Rodbolt should have some advice on that score.
Also read the Engine FAQ on Making oil.
__________________
JB
  #8
Old November 19th, 2007, 09:44 AM
rodbolt rodbolt is online now
there is a tech bulliten out for some of the F115 motors. sometime in 01 or 02 I believe.
engine temp is critical, its mandatory to periodically check the T-stat.
after extended idle times you really need to spend at least 30 min above 4000 RPM and the engine MUST be capeable of 5800 or so at any given load.
unlike carburated engines fuel is injected reguardless of if it can be burned.
excessive combustion pressures due to engine lugging will cause blowby fuel to pass the rings.
periodic leakdown tests are needed as occasionally the ring gaps will line up. I have seen it twice. when they line up the main symptom is making oil.
other than that my F150 can spend hours idling
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Yamaha 4 Strokes TrenchFisherman Yamaha & Suzuki Outboards 17 January 19th, 2008 05:42 PM
12 - 9.9hp yamaha 4-strokes for $200 each?? mountainsailor Yamaha & Suzuki Outboards 7 September 3rd, 2007 11:08 PM
4 Strokes -- Suzuki vs. Yamaha rsbeck Non-Repair Outboard Discussions 2 September 2nd, 2004 08:09 PM
Yamaha 225 Four Strokes ptsearch Yamaha & Suzuki Outboards 5 March 3rd, 2004 02:28 AM
Yamaha 225 Four Strokes ptsearch Boat Topics and Questions (not engine topics) 1 March 2nd, 2004 03:48 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
