Re: 1984 50hp merc new owner little problems
I have a little experience with the 84 50hp. I suggest using the NKG BUHW spark plug, it is a fixed gap plug. The primer bulb isn't hard when mine is running. But, if you think it is the bulb causing your problem, just squeeze it gentle when the motor is running to keep the fuel coming to the carbs.
With out having more detail about the motor and things you have checked, it will be hard to answer your question. Based on what you said and a little assuming, I'd say that the motor is not hitting on all cylinders. That could be your plugs or plug wire, one of your carbs, a faulty switch box or coil pack, if equipped. It could be that your motor is getting hot, is there water coming from the tattle tail?
If you could, provide more information. I'll try to help.
