  #1
Old November 13th, 2007, 10:37 PM
jimmyr jimmyr is offline
Default 1977 85hp evinrude need wiring diagram
no spark need to trace wires to see where my loss of power is.PLEASE HELP!!!!!
  #2
Old November 13th, 2007, 11:05 PM
HighTrim's Avatar
HighTrim HighTrim is offline
Default Re: 1977 85hp evinrude need wiring diagram
Welcome to iboats. First thing that you should do is get yourself a manual, they will pay for themselves a million times over. How were you testing for spark, an inline tester set to 7/16 of an inch? If there was for sure no spark, start here.
1. Note: If the ignition only fires with the spark plugs out, the timer base is likely weak or the engine is not spinning fast enough. See # 6 and #8.
2. Disconnect the black yellow kill wire and retest. If the engines now has fire, the kill circuit has a fault-possibly the keyswitch, harness or shift switch.
3. Disconnect the yellow wires from the stator to the rectifier and retest. If the engine fires, replace the rectifier.
4. Check the stator resistance. You should read approximately 500 ohms from the brown wire to the brown/yellow wire.
5. Check the DVA output from the stator. You should have a reading of at least 150V or more from the brown wire to the brown/yellow wire (while connected to the pack).
6. Check the timer bases resistance from the black/white wire to the white/black wires. Reading should be 10-20 ohms.
7. Check the DVA output from the timer base. A reading of at least 0.5V or more is needed from the black/white wire to the white/black wires (while connected to the pack) to fire the pack. If the output is low, you may try to reset the air gap between the timer base sensor and the triggering magnet using a sensor gap gauge or use the following procedure outlined below.
a. Loosen the two mounting screws on the sensors and the nuts located in the epoxy on the outside of the heat shield of the timer base.
b. Slide the sensors in toward the crankshaft until the sensor touches the stop boss located at the base of the sensor mounting area. Tighten the mounting screws.
c. Coat the face of the sensor with machinists bluing or equivalent.
d. Install the flywheel according to the service manual and crank the engine over.
e. Remove the flywheel and check to see if the trigging magnet struck the sensor face. If it did, back the sensor out approximately 0.005” and repeat steps C, D and E.
f. If the ignition fired, finger tight the nut on the outside of the heat shield and coat it with RTV.
g. f still no fire, replace the sensor.
8. Check the DVA voltage on the black/white wire to engine ground. You should have a reading of at least 150V or more (while connected to the pack). If the reading is low, disconnect the trigger wires from the pack and recheck the black/white terminal on the pack. If the voltage jumps up to an acceptable reading, the timer base may have a problem in the internal wiring (A thin spot in the insulation on one wire).
9. Check the cranking RPM. A cranking speed of less than 250-RPM will not allow the system to fire properly.
__________________
Chris
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
TILT AND TRIM WIRING DIAGRAM FOR A 1987 85HP FORCE imported_fullforce Force & Chrysler Outboards 6 October 20th, 2006 12:31 AM
70s johnson 85hp wiring diagram casi77 Johnson & Evinrude Outboards 4 August 23rd, 2006 11:33 PM
Wiring Diagram for a 1977 Chrylser Outboard rlongxr7 Force & Chrysler Outboards 1 July 31st, 2005 08:54 AM
1977 evinrude 35hp wiring diagram Pamtony2000 Johnson & Evinrude Outboards 1 May 30th, 2005 08:05 AM
1977 35HP Evinrude - Need Wiring Diagram turtle1173 Johnson & Evinrude Outboards 5 April 27th, 2005 04:56 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
