  #1
Old November 13th, 2007, 01:06 PM
hawilson2 hawilson2 is offline
Default Old Yamaha controls-new Yamaha motor ???
I am looking at buying a 2005 Yamaha 115 4 stroke. I already have (and love) a 1996 C115 2 stroke Yamaha installed. Can I use the old Yamaha binnacle mount control box and guages (2 - tach and speed) with the new engine? I believe I will need to buy a wiring harness adapter. Is that correct? Thanks in advance.
  #2
Old November 13th, 2007, 02:32 PM
Raven Raven is offline
Default Re: Old Yamaha controls-new Yamaha motor ???
I did essentially the same thing.. replaced a 1996 200hp vmax with a 2005 F150 4-stroke. The dealer installed the motor using the same controls, instruments and wiring. The issues to date are:
a. trim indicator doesn't work. Dealer says motor/indictor are incompatable. Don't know if that is true or not.
b. Oil sensor: I don't know whether the oil indicator on the old gauges are doing anything or not. If they are to indicate oil pressure then they don't appear to be working since there is no indication zero oil pressure when the engine is off.
c. Overheat indicator and buzzer. I can't tell if these are functional or not. I do not know a way to test it.
This setup had been working for a year but now I am having problems with zero fuel pressure (see earlier post) and do not know whether the problem is in the old controls or not.
  #3
Old November 13th, 2007, 09:17 PM
rodbolt rodbolt is offline
trim indicate wont work, tach will but nio visuals.
buy the later tach
the trim harness is the same.
in 95 they changed from round to square connectors, in 99 they changed to a 2 wire trim sender.
the later tach is selectable for 4 or 2 stroke,2 or 3 wire trim sender and 6 or 12 pole altenator.
to test the overheat on some of the F motors requires a resistor jumped acrossed the temp sensor and shorting the temp switch.
its all in the Marine Technical Guide.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Yamaha controls gla8460421 Yamaha & Suzuki Outboards 1 January 21st, 2007 09:26 PM
Yamaha Motor on Boat w/ Mercury Controls PenleyFace Yamaha & Suzuki Outboards 1 April 21st, 2006 04:35 AM
Yamaha controls Dave Larrieu Non-Repair Outboard Discussions 4 July 24th, 2004 03:36 AM
40 yamaha controls Billnicole Yamaha & Suzuki Outboards 1 May 26th, 2004 04:43 PM
YAMAHA 703 CONTROLS REINMAN Boat Topics and Questions (not engine topics) 2 February 19th, 2003 06:53 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
