Okay I changed out the head gasket on my 98 3.0L Merc. Then I set the timing according to the manual that don s sent me in a link.
A little background on what I found w/ timing. You have to use a jumper wire on the distributer and join the leads from the shift interrupt switch. Did that. When I started her up and checked the timing it was 12 BTDC It was supposed to be 1 BTDC. So I rotate the distributor to get it down to 1 ATDC (according to the SB) The engine idles super rough. So I turn the idle screw and it evens out. Purrs like a kitten. I take off the jumper wire, hook up the leads from the shift interrupt switch and fire her back up. The timing moves up to 12 BTDC, which is what the manual says it is supposed to do. It idles like a dream. I go "throttle only" on the throttle and get her up to about 2500 rpms just to make sure things are going right and they are.
Fast forward to today, I get to the lake, put the boat in, start her and everything is fine. I go to power out and it gets up to about 2k rpms and dies. Start her up again and she dies at the same rpm's again. She will go at about 1500 to 1800 rpms, just enough to get me back to the trailer. Now I'm lost. When I go throttle only it seems to be working.
Anyone have any thoughts? Something I should be checking? Right now I am leaning towards the carb and it not having the right settings on the screws.
