Hello to all, and thanks up front for any help I may get.
I have a few questions about my motor and alot of this is new to me...
Idle: I can run the engine all day when I give it some gas. runs really good, but when i pull it back to idle to shift in to gear, it dies.
Takeoff: I have got it to shift into gear a couple of times, by revaing it up and shifting into gear fast, but then it will not get up to plain.
Solenoid: I took the solenoid off to have it tested, and forgot to write down the color codes. I rem the top and the bottom connetions, but the two little connections, in the middle of the solenoid, im not sure of, i have a black wire and two yellow wires. I connected it back with the two yellows on the top of the two little connections, that is the top side of the selenoid, next ot the connection where the battery connects. and the black one of the bottom of the two little connections next to the one that connects to the starter.
Any help would be great.
