Jon_Glastron
- Sep 23, 2007
- 36
I finally purchased a boat/motor/trailer used.
The boat is a 1985 16foot Glastron with a 100 hp merc.
The trailer says Conroy on it.
On the way home from picking it up, we had a problem. The brackets the hold the bunks up laid down flat and the boat sat down on the trailer instead of the bunks.
The bunk brackets are welded on the triailer in an "L" shape. I managed to get the boat home but now I need to figure out what to do.
My thought are to somehow jack the boat up high enough to remove the bunks boards, straighten the bent brackets, reinforce the brackets, reinstall the bunk boards and I should be good to go???
How can I jack the boat up? Can I simply use a floor jack with a 2x6 on the top in the center bottom of the boat in the back and front?
Thanks for info you can add.
EDIT.
Finally found the correct serch term on how to jack the boat up. I am still a little confused. If I lower the front of the trailer and crib the back of the boat, then raise the front, this should lift the back off of the trailer.
The can I simply put a floor jack under the front center "V" and jack the front of the boat until it clears the bunks?
Do I then need to some somehow install boards similar to the bunks from the front crib to the back to support the boat along its length?
I am considering working on the trailer while it is under the boat, any thought goos or bad?
EDIT.
