I have a 1991 Johnson 120 V4 Mod no VJ120TLEIE. I am trying to replace the water housing and impeller with a new kit. I have a SELOC manual and have done everything else up to shift disconnect (plug wires off, pos battery cable off, and starter motor removed) I am stuck on disconnecting the shift shaft. The manual states it is under the lower carb and shows a picture where it is. But the picture is terrible and it looks like the whole front of the motor is removed to take the pic down to the intake. I think I see the bolt they are talking about but am unsure. Even if it is the bolt they are talking about I have yet to find a way to reach it with a wrench or socket.
Is there some sort of trick to disconnecting it? Do I have to remove a bunch of stuff or am I just going about it wrong? And finally should I even be looking for a bolt? The manual later states, in lower unit install, to reinstall the bolt or pin for the shift disconnect. Got the manual, have some mechanincal skill, need help to get past this! :
