  #1
Old November 10th, 2007, 10:22 AM
frednick1 frednick1 is offline
Default 1988 - 90HP 3 cylinder Mariner - Fuel leaking
Hi Guys,
You have been a great help to me in the past with all sorts of Mariner engine problems.
But here's one that I have not been able to cure.
I fish with this 90HP Mariner engine and it runs fantastic thanks to many of you.
I start it up and pull away from the ramp aok. I run over to my favorite spot and turn the engine off. Sometimes I tip the Mariner engine up and sometimes I don't. Makes no difference to the problem.
I drop the trolling motor and start to fish. Sometimes but not always (and this is why I am so confused) the motor will start to leak fuel into the lake and, since I am in front fishing, I smell it before I see it. I go back there and there is a big slick on the water behind the boat. This does NOT happen every time. Sometimes it's fine. No leaks.
I have tried to find the leak but it only happens when I am out fishing and only sometimes. I can't get it to leak when I squeeze the fuel line primer bulb or at any other time. I can't see where it is coming from and it is really hard to get the clam-shell cover off the engine when I am on the lake.
I have taken it off and launched the boat without a cover but I still can't see where it's leaking from.
Anybody know what's going on here?
Thanks.
Frednick1
__________________
Fred's First Rule: There is no amount of money that's too much for a guy to spend on his hobbies.
Fred's Second Rule: If the toilet runs over and it's not your house, it's not your problem.
Fred's Third Rule: There is no speed at which you can drive that the jerk behind you will not pass.
  #2
Old November 10th, 2007, 08:47 PM
Laddies Laddies is offline
Default Re: 1988 - 90HP 3 cylinder Mariner - Fuel leaking
If it only leaks when you trim it up thats normal, when the engine is tilted it's just like tipping a glass full of water on it's side it will spill some out, if hat the case and you don't want it to happen you you will have to run the fuel out of the carbs
  #3
Old November 11th, 2007, 05:37 PM
Hi Laddies of Northern Michigan,
That's a good idea. I had not thought of that. Next time, I will run the gas out of the engine and then see if it leaks. I would guess it will not.
BTW, it leaks no matter if I tip (trim) it up or not. But not always. Sometimes it's fine in both positions. Sometimes it leaks in both positions.
I know that's weird. But that's just what it does.
But running the engine out of gas would actually save fuel since I think it leaks out more than it would use if I ran it dry.
Thanks for the idea.
frednick1
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
60HP 2 cylinder Japanese Mariner won't run on top cylinder? TigerSharkCrazy Mercury & Mariner Outboards 1 September 4th, 2007 08:44 PM
Water in cylinder 1988 90hp Johnson jdupree Johnson & Evinrude Outboards 19 October 26th, 2006 06:56 AM
94 90HP 3 CYLINDER MARINER 24pontoon Mercury & Mariner Outboards 3 December 9th, 2005 03:35 PM
Mariner 90 - Fuel Leaking steve_0710 Mercury & Mariner Outboards 2 November 12th, 2003 04:05 PM
Leaking Cylinder Troy_from _Oz Mercury & Mariner Outboards 16 December 20th, 2002 01:53 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
