  #1
Old November 9th, 2007, 09:44 PM
jbjennings's Avatar
jbjennings jbjennings is offline
Default 7.5hp '55 evinrude FUEL MIX BOOGER! F-R?
Guys,
As you may have noticed on another thread, I have messed up the fuel mixture on my 'rude. It runs flawlessly but I have been using 24:1 instead of 16:1 as it should be. I have only run about 3 gallons through it at this mixture. It runs great but doesn't seem to have any more power than a 5.5hp. Could the extra friction by not having enough oil be causing this? the cowl says 7.5hp. The head has #203656 cast on it, and the exhaust cover has 203374 cast on it. This is a 7.5hp, right? It ran this way from the get-go, never had much power. One fellow posted he got 18mph on a light 12ft. boat with his '55 7.5hp and I can't get near that with mine and I have a fairly light 12 footer also.
Any ideas?
JBJ
  #2
Old November 9th, 2007, 10:55 PM
F_R F_R is offline
Default Re: 7.5hp '55 evinrude FUEL MIX BOOGER! F-R?
Yep, that is the number for a 7.5 exhaust cover. I doubt you have significantly hurt the motor by running that 24:1. It didn't try to sieze did it? Are you sure you are getting full power from both cylinders? Try removing and grounding one plug wire and see how much power it has. Then do the other one. Should be about equal power loss with either.
  #3
Old November 9th, 2007, 11:04 PM
jbjennings's Avatar
Thanks F-R,
No, it never tried to seize, just not as fast as I'd hoped. It does have new coils but I can't remember if I put new condensors on it. Will try grounding plugs and see if anything sign. happens. Also replaced impeller, l.u. seals, so it shouldn't be overheating. I think I'll test it on my "new" 12 footer and see how fast it is on it.
Thanks again,
JBJ
  #4
Old November 10th, 2007, 02:00 AM
wbeaton's Avatar
wbeaton wbeaton is offline
I have a 1955 7.5 hp that won't plane my 12' deep and wide tin boat either. It pushed my old narrow 12' boat up to about 18 mph, but not the bigger one. Hull shape and style make a big difference.
  #5
Old November 10th, 2007, 09:03 AM
JB's Avatar
JB JB is offline
"I have been using 24:1 instead of 16:1 as it should be."
According to the 1964 Johnson Service Manual and to BRP you have been running the correct mixture.
You will do no harm by running 16:1, except for faster carbon buildup and risk of fouling plugs more often, but anyone claiming that 24:1 using TC-W3 oil is harmful is just plain wrong.
__________________
RED SKY at night. . .
JB
  #6
Old November 10th, 2007, 10:49 AM
wbeaton's Avatar
To be honest, I thought OMC had switched to 24:1 for ALL 1950's outboards, but I can't find anything in writing to support it. Either way, I've found its an unwinnable argument.
I run at 24:1 with synthetic oil. I know some run as little as 36:1, 40:1 and OMG 50:1. They will all run on leaner mixes, but the motors longivity is reduced. Obviously, I'm with JB on this one, but you can't go wrong with 16:1 either.
  #7
Old November 10th, 2007, 02:39 PM
R.Johnson R.Johnson is offline
I have the same engine, have always mixed 25-1 with tw-3 oil, never a problem.
  #8
Old November 10th, 2007, 04:07 PM
samo_ott's Avatar
samo_ott samo_ott is offline
I have the '50 7.5hp and ran it all year on 24:1 with fully synthetic oil... Other than the LU full of water (see other thread) it ran well and has noticablely more power than my 1961 5.5hp.
  #9
Old November 10th, 2007, 09:16 PM
jbjennings's Avatar
I'm thinking of putting the 7.5 on my new 12 footer and taking my GPS tomorrow morning duck hunting. Will see how it performs on that boat with some good 16:1 gas (well, close to 16:1 anyway). If I take it I'll post results. Only thing, I love my old '57 18 johnson so much I hate to not run it!
Thanks for your responses,
JBJ
  #10
Old November 11th, 2007, 03:12 AM
samo_ott's Avatar
quack... quack... I dunno, I'd MUCH rather be cruising with the 18... they rock!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Fuel line connection on portable fuel tank for Evinrude 50 HP batman4279 Johnson & Evinrude Outboards 2 July 30th, 2007 09:54 PM
Evinrude 115 fuel/oil mix andyp1961 Johnson & Evinrude Outboards 5 August 3rd, 2005 04:07 AM
Evinrude not getting fuel? lost@sea Johnson & Evinrude Outboards 5 August 1st, 2005 01:32 PM
Evinrude fuel/oil mix mc boating Johnson & Evinrude Outboards 2 April 21st, 2005 10:04 PM
What year is Evinrude & Fuel Pump spitting fuel out hole... bhwebb Johnson & Evinrude Outboards 7 September 22nd, 2003 11:34 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
