  #1
Old November 9th, 2007, 04:10 PM
cwill cwill is offline
Default 1990 Evinrude 200 VRO stalls when put in gear
I got stranded on the lake last weekend. I had a difficult time starting the engine prior to leaving the ramp. Once it started it ran fine to the first fishing hole. When I attempted to leave the engine would die out when I put it in gear. It would idle for a little after i primed it. Could this be the carbs or fuel pump? The primer bulb was not hard. Can I spray a cleaner in the carbs? Any suggestions?
  #2
Old November 9th, 2007, 04:42 PM
HighTrim's Avatar
HighTrim HighTrim is offline
Default Re: 1990 Evinrude 200 VRO stalls when put in gear
Welcome to iboats. When were the carbs last rebuilt? May be time for a bath and rebuild. Check to see if the timer base (starboard side, under the edge of the flywheel, linked to the throttle lever) moves smoothly without sticking when you advance the throttle.
Take the airbox cover off & observe whether the throttle plates are parallel.
Also, the timer base should start it's travel before the throttle plates start to open, else she'll fall flat when you try to accelerate.
If you pump the primer bulb will it pick up? If so the carb floats could be improperly set or defective,failing fuel pump air motor diaphragm ,leaky or dislodged pulse hose between crankcase and fuel pump, bad primer bulb, etc... If you do get a new primer bulb, get the BRP one, not a cheap aftermarket.
__________________
Chris
  #3
Old November 10th, 2007, 12:19 AM
1730V 1730V is offline
Spraying cleaner in the carbs will do absolutely no good and could easily damage the engine.
  #4
Old November 10th, 2007, 07:38 AM
Silvertip Silvertip is offline
I agree with 1730V -- carb cleaner sprayed into the carb throught cleans only the throat -- it doesn't get to the heart of the problem which lies "inside" the carb. Carb cleaner can indeed cause damage as there is no lubricant in that stuff. However, add a can of SeaFoam to the fuel as the first line of attack. It is an excellent fuel system cleaner and may help. You can use it all the time as a preventive measure as well. If the problem continues a carb rebuild is very likely needed.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1990 Evinrude 60 HP Stalls 18RTO Johnson & Evinrude Outboards 2 February 14th, 2006 08:34 AM
1990 60hp Evinrude stalls GaryH Johnson & Evinrude Outboards 2 June 10th, 2005 12:45 PM
Evinrude 135 stalls when trying to put in gear 76chieftain Johnson & Evinrude Outboards 1 June 14th, 2004 07:20 PM
77 evinrude stalls when shifted into gear johnl523 Johnson & Evinrude Outboards 1 July 14th, 2002 04:05 PM
65 hp evinrude won't rev up and stalls when put into gear nick1981 Johnson & Evinrude Outboards 1 July 3rd, 2002 05:03 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
