  #1
Old November 8th, 2007, 05:16 PM
skigolfnut skigolfnut is offline
Default mercury 1992 200hp fuel starving under load
I have a barefoot sanger with a 1992 200 hp 2.5 xri I bought it in an estate sale, gas tanks really bad,sat for 3 years. Removed them and cleaned them, but every now and then after running all day barefooting engine wont get up the rpm's, and it will rev up in nuetral but wont go under a load.
I keep changing all the filters and still looks like varnish flakes every now and then in the inline fuel filters, compression is good, good spark, has anybody ever heard of chainging out the little filters on the actual fuel injectors?
I have looked for the inline filter between the fuel pump and the pressure regulator and dont see one.
any suggestions?
  #2
Old November 8th, 2007, 08:58 PM
Laddies Laddies is offline
Default Re: mercury 1992 200hp fuel starving under load
You might try some carb/fuel injector cleaner and if that don't work take it to a good dealer if you keep running lean you will damage the engine and it will end up at a dealers with a even larger repair bill
  #3
Old March 16th, 2008, 09:56 PM
Unhappy Re: mercury 1992 200hp fuel starving under load
Dealer is baffled, no clue, took it out the other day and it ran fine, no problems,then 2 days later, ran fine for 2 hours then, starving for fuel,
headed back to the marina, slow, then about half way back, it started to kick in and it ran fine again, ran fine for another hour then, back to starving for fuel, then it was time to call it a day.
checked both in line filters, (clean), spin on filter( clean)
put it in nuetral, it can rev up to red line, but put a load on it, and no go,
just about 2000 rpm's, is their a filter screen at the fuel injectors?
help any suggestions Skigolfnut
  #4
Old March 16th, 2008, 11:47 PM
Faztbullet's Avatar
Faztbullet Faztbullet is offline
You really need to clean the vapor separator if this engine has set this long. The separator has a needle, seat & float inside it controling inlet fuel from square low pressure fuel pump. Electric fuel pump also has a filter on the bottom of it. Fuel to injectors are are filtered once in round filter above pump and at the injector itself. The filters in the injectors are replaceable but need to be cleaned and flowed. Do not even try to clean this with a additive such as Quickleen or Seafoam and others, as they will not remove debris from filters because debris cannot be broken down small enough. If it is injectors send to Brucato. Cleaned, new filters and matched flowed for under $ 180.00 unless you have a bad one.
  #5
Old March 17th, 2008, 03:18 PM
Thanks,
I have done all the above from day 1 when I took over the boat, I finally removed the saddle tanks and cleaned all the varnish flakes off of the walls, no wonder my inline filters looked like crud after a couple of outings, I am going to take a look at that vapor seperator needle float valve again, I am thinking that a couple of big chips keep circulating around and around in the fuel management system and catching on the float valve from time to time.
  #6
Old March 17th, 2008, 10:51 PM
rimojop rimojop is offline
Are you positive it is a fuel issue?
I've had 2.5s that will run great at idle and rev-up in neutral.
Only to find a bad switchbox on the ign side of things.
When a box fails the engine loses 1 bank of cylinders.
It will start and idle and rev in neutral, but when you go to throttle up
it just bogs down.
Just a thought!
Good luck.
  #7
Old March 18th, 2008, 10:59 AM
THANKS,
how do I check for that? I have a mercury mechinic I can call, I just figured it was a fuel issue, because heading back to the marina at 2000 rpm and boat will not get on plane, then all of a sudden, it kiks in and runs fine for a while, then after slowing down for a no wake zone, it is back to no power. never thought it could have been anything else.
thanks, again,
  #8
Old March 19th, 2008, 11:02 AM
CharlieB CharlieB is offline
You really do need to tap into the fuel system to monitor fuel pressure during the faulty performance.
These injection pumps do act strange as they begin to die, still running but intermittantly failing to provide adequate pressure for full performance.
  #9
Old March 19th, 2008, 11:59 AM
thanks,
I am going to take a timing light with me to the lake, and when it acts up again, I am going to check each plug wire to see if they are getting spark or not. If they are not getting spark it will point to a weak Stator. if it is getting spark and running slow it is fuel or ecu problems,
Many thanks for everyones help, I will keep yuall posted.
thanks,
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Powerhead removal - 1992 200HP Mercury jdupree Mercury & Mariner Outboards 6 November 1st, 2007 05:27 PM
Mercury 200HP EFI Fuel Pump Problem daguvna Mercury & Mariner Outboards 4 March 28th, 2007 12:02 PM
1992 200hp Mercury 2.5l offshore jdupree Mercury & Mariner Outboards 2 January 16th, 2007 06:10 PM
Fuel pump diaphram kit question/ 1989 200hp Mercury gss036 Mercury & Mariner Outboards 10 October 14th, 2004 05:43 PM
fuel pump for mercury 200hp efi??? is dealer ripping me off dj_kev Mercury & Mariner Outboards 6 September 29th, 2003 05:19 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
