Re: temp sending unit
Not sure what a Mag 3 is, but your alarms should not be sounding just because you disconnected it. The temp sending unit has nothing to do with the alrarms, it just sends a signal to the guage. Overheat device closes a circuit by grounding the wire, thus sending a signal that cause the alarm to go off.
Teleflex says the sender value @ 75 degress is 550-750 ohms, 55 ohms@ 212 degress. Hope that helps you out.
You really need an OEM manual.
